torsnook
Feb 06, 2014Aspirant
Problem with Firmware upgrade
Hi I have just upgraded my ReadyNAS Duo to 4.1.13 firmware It all appears to have worked except I can't access the front panel. I can access the drives and the normal add ons seem to work I just can...
data_burger
May 06, 2014Aspirant
bOz-NAS:/etc/init.d# tail -n 100 /var/log/frontview/error.log
[Mon May 05 00:06:38 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: scriptname in /c/webroot/loadavg/nasinfo.php on line 590, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:40 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: prev in /c/webroot/loadavg/nasinfo.php on line 302, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:40 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: allfs in /c/webroot/loadavg/nasinfo.php on line 311, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:40 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: my_parts in /c/webroot/loadavg/nasinfo.php on line 496, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:41 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: vpsstat in /c/webroot/loadavg/nasinfo.php on line 744, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:41 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: vpsstat in /c/webroot/loadavg/nasinfo.php on line 792, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:41 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: tcpstatus in /c/webroot/loadavg/nasinfo.php on line 565, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:41 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: mysql_head in /c/webroot/loadavg/nasinfo.php on line 1121, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:41 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: vpsstat_div in /c/webroot/loadavg/nasinfo.php on line 1139, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:06:41 2014] [error] [client 192.168.0.5] PHP Notice: Undefined variable: mysql_div in /c/webroot/loadavg/nasinfo.php on line 1143, referer: https://192.168.0.110/nasmon/nasinfo.php
[Mon May 05 00:09:07 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
Bad free() ignored (PERL_CORE) at /frontview/lib/Frontview.pm line 2.
[Mon May 05 00:10:03 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
[Mon May 05 00:10:39 2014] [warn] pid file /var/log/frontview/apache-ssl.pid overwritten -- Unclean shutdown of previous Apache run?
[Mon May 05 00:10:40 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.3.28-0rnx1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
[Mon May 05 00:18:11 2014] [error] [client 192.168.0.5] Premature end of script headers: message_handler.cgi, referer: https://192.168.0.110/admin/
[Mon May 05 00:22:29 2014] [notice] Graceful restart requested, doing restart
apache-ssl: Could not reliably determine the server's fully qualified domain name, using 192.168.0.110 for ServerName
[Mon May 05 00:22:58 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
[Mon May 05 00:23:11 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.3.28-0rnx1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
[Mon May 05 00:37:57 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
Bad free() ignored (PERL_CORE) at /frontview/lib/get_handler.pm line 2.
Bad free() ignored (PERL_CORE) at (eval 3) line 3.
[Mon May 05 00:38:42 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
[Mon May 05 00:39:37 2014] [warn] pid file /var/log/frontview/apache-ssl.pid overwritten -- Unclean shutdown of previous Apache run?
[Mon May 05 00:39:37 2014] [notice] Apache/2.2.6 (Debian) mod_ssl/2.2.6 OpenSSL/0.9.8e DAV/2 PHP/5.3.28-0rnx1 mod_apreq2-20051231/2.6.0 mod_perl/2.0.3 Perl/v5.8.8 configured -- resuming normal operations
[Mon May 05 00:41:22 2014] [error] [client 192.168.0.5] Premature end of script headers: message_handler.cgi, referer: https://192.168.0.110/admin/
[Mon May 05 00:45:59 2014] [notice] caught SIGTERM, shutting down
[Mon May 05 00:54:43 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
[Mon May 05 00:55:46 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
PHP Fatal error: Unable to start curl module in Unknown on line 0
[Mon May 05 12:35:11 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
[Mon May 05 12:35:50 2014] [warn] RSA server certificate CommonName (CN) `192.168.168.168' does NOT match server name!?
[Mon May 05 13:01:45 2014] [warn] RSA server certificate CommonName (CN) `192.168.0.110' does NOT match server name!?
[Mon May 05 13:02:55 2014] [warn] RSA server certificate CommonName (CN) `192.168.0.110' does NOT match server name!?
[Mon May 05 13:19:11 2014] [warn] RSA server certificate CommonName (CN) `192.168.0.110' does NOT match server name!?
[Mon May 05 13:19:56 2014] [warn] RSA server certificate CommonName (CN) `192.168.0.110' does NOT match server name!?
[Mon May 05 14:05:10 2014] [warn] RSA server certificate CommonName (CN) `192.168.0.110' does NOT match server name!?
[Mon May 05 14:06:27 2014] [warn] RSA server certificate CommonName (CN) `192.168.0.110' does NOT match server name!?
Bad free() ignored (PERL_CORE) at (eval 2) line 3.
Here's what ps aux gives:
bOz-NAS:/etc/init.d# ps aux
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.3 2000 880 ? Ss 05:41 0:04 init [3]
root 2 0.0 0.0 0 0 ? SN 05:41 0:00 [ksoftirqd/0]
root 3 0.0 0.0 0 0 ? S< 05:41 0:00 [events/0]
root 4 0.0 0.0 0 0 ? S< 05:41 0:00 [khelper]
root 5 0.0 0.0 0 0 ? S< 05:41 0:00 [kthread]
root 10 0.0 0.0 0 0 ? S< 05:41 0:00 [kblockd/0]
root 13 0.0 0.0 0 0 ? S< 05:41 0:00 [khubd]
root 41 0.0 0.0 0 0 ? S 05:41 0:00 [pdflush]
root 42 0.0 0.0 0 0 ? S 05:41 0:00 [pdflush]
root 43 0.0 0.0 0 0 ? S 05:41 0:00 [kswapd0]
root 44 0.0 0.0 0 0 ? S< 05:41 0:00 [aio/0]
root 45 0.0 0.0 0 0 ? S< 05:41 0:00 [cifsoplockd]
root 46 0.0 0.0 0 0 ? S< 05:41 0:00 [cifsdnotifyd]
root 92 0.0 0.0 0 0 ? S< 05:41 0:00 [kvblade]
root 93 0.0 0.0 0 0 ? S 05:41 0:00 [mtdblockd]
root 106 0.0 0.0 0 0 ? S 05:41 0:00 [hotplug-sata]
root 120 0.0 0.0 0 0 ? S 05:41 0:00 [hotplug-gmac]
root 174 0.0 0.0 0 0 ? S< 05:41 0:00 [md0_raid1]
root 178 0.0 0.0 0 0 ? S< 05:41 0:00 [md2_raid1]
root 182 0.0 0.0 0 0 ? S< 05:41 0:00 [md1_raid1]
root 538 0.0 0.7 4992 1760 ? Ss 05:42 0:00 /usr/sbin/sshd
root 758 0.0 0.4 2176 1040 ? Ss 05:42 0:00 noflushd -v -n 15
daemon 772 0.0 0.2 2240 624 ? Ss 05:42 0:00 /sbin/portmap
root 779 0.0 0.4 2128 960 ? Ss 05:42 0:00 /sbin/syslogd -m 0
root 795 0.0 0.3 2016 720 ? Ss 05:42 0:00 /sbin/klogd -x -c 3
daemon 799 0.0 0.3 2480 864 ? Ss 05:42 0:00 /usr/sbin/atd
root 802 0.0 0.3 2000 704 ? Ss 05:42 0:00 /usr/sbin/inetd
root 817 0.0 0.5 2656 1264 ? Ss 05:42 0:00 /usr/sbin/cron
admin 821 0.0 0.8 3648 1840 ? Ss 05:42 0:00 avahi-daemon: running [bOz-NAS.local]
root 822 0.0 0.7 4672 1776 ? Ss 05:42 0:00 /usr/sbin/cupsd
root 848 0.0 2.4 16048 5472 ? Ss 05:42 0:00 /usr/sbin/smbd -D
root 856 0.0 1.6 16048 3696 ? S 05:42 0:00 /usr/sbin/smbd -D
root 1242 0.0 0.1 2080 384 ? Ss 05:42 0:00 udhcpc -i eth0 -H bOz-NAS -t 3 -S -n
root 1260 0.0 0.3 1984 704 ? Ss 05:42 0:00 /usr/sbin/raidard
root 1276 0.0 0.3 2000 864 ? Ss 05:42 0:01 /usr/sbin/upnpd eth0
root 1284 0.0 0.4 3008 1104 ? S 05:42 0:00 /usr/sbin/cnid_metad -l log_info -f /var/log/netatalk.log
root 1287 0.0 0.2 2080 624 ? S 05:42 0:00 /usr/sbin/lld2d eth0
root 1290 0.0 2.0 19856 4752 ? Ss 05:42 0:02 /usr/sbin/minidlna
root 1294 0.0 2.0 19856 4752 ? S 05:42 0:00 /usr/sbin/minidlna
root 1295 0.0 2.0 19856 4752 ? RN 05:42 0:01 /usr/sbin/minidlna
root 1298 0.1 1.3 8608 3056 ? S 05:42 0:37 /usr/sbin/afpd -U uams_dhx.so,uams_dhx2.so -c 50 -n bOz-NAS
root 1309 0.0 0.9 5536 2096 ? S 05:42 0:00 /bin/bash /opt/p2p/bin/leafp2p.sh
root 1311 0.0 1.0 5616 2448 ? S 05:42 0:00 /opt/p2p/bin/leafp2p -n
root 1315 0.0 0.9 5536 2096 ? S 05:43 0:00 /bin/bash /opt/remote/bin/remote.sh
root 1317 0.0 2.1 6864 4784 ? S 05:43 0:00 /opt/remote/bin/remote
root 1323 0.1 17.6 116096 40032 ? Ss 05:43 0:22 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
admin 1344 0.0 0.1 1840 400 ? SNs 05:43 0:00 /usr/share/bittorrent/bin/btdog 98
admin 1345 0.0 1.8 40080 4224 ? SN 05:43 0:00 /usr/share/bittorrent/bin/bt --daemon-loop
admin 1350 0.0 1.8 40080 4224 ? SN 05:43 0:00 /usr/share/bittorrent/bin/bt --daemon-loop
admin 1351 0.0 1.8 40080 4224 ? SN 05:43 0:00 /usr/share/bittorrent/bin/bt --daemon-loop
admin 1354 0.0 1.8 40080 4224 ? SN 05:43 0:16 /usr/share/bittorrent/bin/bt --daemon-loop
admin 1355 0.0 1.8 40080 4224 ? SN 05:43 0:00 /usr/share/bittorrent/bin/bt --daemon-loop
admin 1366 0.0 1.8 40080 4224 ? SN 05:43 0:00 /usr/share/bittorrent/bin/bt --daemon-loop
root 1376 0.0 2.3 16176 5216 ? S 05:43 0:01 /usr/sbin/mt-daapd
root 1385 0.0 2.3 16176 5216 ? S 05:43 0:00 /usr/sbin/mt-daapd
root 1386 0.0 2.3 16176 5216 ? S 05:43 0:00 /usr/sbin/mt-daapd
root 1427 0.0 1.3 9520 3024 ? Ss 05:43 0:00 nmbd -D
root 1477 0.0 0.5 2400 1184 ? Ss 05:43 0:02 /frontview/bin/monitor_enclosure
admin 1599 0.1 14.9 49712 33936 ? S 05:44 0:30 /usr/bin/python CouchPotato.py --daemon --data_dir /c/.cpserver --p
root 1697 0.0 0.3 2016 896 ttyS1 Ss+ 05:44 0:00 /sbin/getty -L ttyS1 9600 vt100
admin 1715 0.0 14.9 49712 33936 ? S 05:44 0:00 /usr/bin/python CouchPotato.py --daemon --data_dir /c/.cpserver --p
admin 1716 0.0 14.9 49712 33936 ? S 05:44 0:14 /usr/bin/python CouchPotato.py --daemon --data_dir /c/.cpserver --p
root 1717 0.0 17.6 116096 40032 ? S 05:44 0:00 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1718 0.0 17.6 116096 40032 ? S 05:44 0:00 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1719 0.0 17.6 116096 40032 ? S 05:44 0:01 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1720 0.5 17.6 116096 40032 ? S 05:44 2:08 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1721 0.0 17.6 116096 40032 ? S 05:44 0:00 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1723 0.0 17.6 116096 40032 ? S 05:44 0:05 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1726 0.0 17.6 116096 40032 ? S 05:44 0:00 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 1727 0.1 17.6 116096 40032 ? S 05:44 0:25 /usr/sbin/ntop -d -L -u root -P /var/lib/ntop --skip-version-check
root 5562 0.0 2.0 14000 4624 ? Ss 10:56 0:02 sshd: root@pts/0
root 5565 0.0 1.0 5680 2448 pts/0 Ss 10:56 0:00 -bash
root 5843 0.0 0.5 3136 1328 ? S 11:23 0:00 /USR/SBIN/CRON
root 5844 0.0 0.7 3024 1632 ? Ss 11:23 0:00 /bin/sh -c /usr/bin/empty_exim &>/dev/null
root 5845 0.0 0.7 3024 1632 ? S 11:23 0:00 /bin/bash /usr/bin/empty_exim
root 5936 0.0 0.4 3120 1008 ? S 11:33 0:00 sleep 600
root 6038 0.0 0.6 3360 1424 pts/0 R+ 11:42 0:00 ps aux
Thanks for your prompt reply :)
