torsnook
Feb 06, 2014Aspirant
Problem with Firmware upgrade
Hi I have just upgraded my ReadyNAS Duo to 4.1.13 firmware It all appears to have worked except I can't access the front panel. I can access the drives and the normal add ons seem to work I just can...
data_burger
May 06, 2014Aspirant
Fixed (by a fluke :)
So I tried installing the PHP5_5.3.28-sparc-4.5.5.bin by copying it to the /opt directory, chmodding to +x and installing using
# ./PHP5_5.3.28-sparc-4.5.5.bin
But. it then complained it couldn't find the addons.conf file. So I moved it to the /etc/frontview/addons folder and ran the above again (without backing up the contents of the folder first - I know...) which gave different error msgs but also deleted everything in said folder. Ooops.
So I decided to run an OS restore and frontview came back to life, albeit slightly unhappy and not all files were recreated in the /etc/frontview/addons folder. But enough to access via https and ssh.
Will keep going and report my results.
Bartek
Bartek
