Kalle13
Oct 20, 2016Tutor
Problem with LACP after update 6.6.0 -> no connection possible
Hello fellow Netgear users, first of all I need to say I am very angry about Netgear. After the new cyber firmaware-update 6.6.0 several things won't work any more. Do they test their software or ...
- Oct 22, 2016
Hi evan2,
thank you for your reply!
My switch is a TP-SG3210. The hash setting is on "SRC IP + DEST IP" (the other option is "SRC MAC + DEST MAC"). This is the the detail info from the switch:
Detail Info:
Group Number: LAG1
LAG Type: LACP
Port Status: Enable
Rate: Auto
Port mirror: Disable
Ingress Bandwidth (bps): --
Egress Bandwidth (bps): --
Broadcast Control (bps): --
Multicast Control (bps): --
UL Control (bps): --
QoS Priority: CoS 0
Join VLAN: 1
Now I've seen that there is a VLAN. Right away I`ve created a VLAN 1 on the NAS. (On first try it got no internet connection. I had to enter my DNS Server in the VLAN connection.) Now it seems to work, but I`ll have a look on it for a few days so to see if it works properly.
I'll will report to you guys if it works or not.
Best regards
Kalle
evan2
Oct 21, 2016NETGEAR Expert
Hi Kalle13 ,
I can't reproduce the issue on RN214 which connect to Netgear switch GS728TPS using LACP Layer 2+3 or Layer 3+4
Could do you provide detail information? I want to reproduce the issue.
Could do you tell me which Hash Type you are using on LACP mode? and what is your Power timer setting?
What switch are you using?
Oct 21, 2016Guru - Experienced User
Also, do you have jumbo frames enabled? Some switches configure the MTU of the bond separately from the MTU of the interfaces (most Netgear switches seem to do that).
- Kalle13Oct 22, 2016Tutor
Hi StephenB,
No, I haven`t enabled Jumbo Frames. My MTU setting is allways 1500.
Best regards
