superandrea
Nov 11, 2012Aspirant
Problem with New Backup Job in FrontView
I have browsed every possible place, there are a couple of look-alike subjects on the forum but none gives a solution for the following problem: "the source path is invalid. please check the path and...
superandrea
Nov 15, 2012Aspirant
Dear CaseyH,
thank you for your reply and question - What permissions should I have for this situation? I can access the folder from multiple sources (windows explorer, readynas remote, Raidar) but seems that only when files are accessed from Raidar I can do changes/delete some files. Does this affects also backup functions?
I have tried to backup some other folders on the same location/source (media), and it seems that they work/can be copied. And that confuses me even more.
Sorry if my questions sound blunt, but for me the whole network backup thing is still in early fase of learning...
Anyway, many thanks for your assistance and looking forward to any solution available !!!
