superandrea
Nov 11, 2012Aspirant
Problem with New Backup Job in FrontView
I have browsed every possible place, there are a couple of look-alike subjects on the forum but none gives a solution for the following problem: "the source path is invalid. please check the path and...
CaseyH
Nov 16, 2012NETGEAR Expert
Superandrea,
Try the following:
Under "Shares\Shares Listing\CIFS\Advanced Options" clicking the check box next to "Set ownership and permission for existing files and folders in this share to the above settings. This option is useful in cases where you are changing security levels and need to workaround file access problems." then clicking Apply. This will reset the permissions on the folders and show allow you access to them again.
Try the following:
