superandrea
Nov 11, 2012Aspirant
Problem with New Backup Job in FrontView
I have browsed every possible place, there are a couple of look-alike subjects on the forum but none gives a solution for the following problem: "the source path is invalid. please check the path and...
superandrea
Nov 21, 2012Aspirant
Hi CaseyH,
I have managed to find a kind of a solution for the problem - I am backing up the whole 'videos' folder to backup - it is a bit more time consuming, I admit. Now I have different problem. As I am backing up to my external hard drive(s), when I unplugged them and after use with my PS3 returned and reconnected to my Readynas Ultra 2 I cannot write anymore to these drives. If I go to Shares\Shares Listing\CIFS\Advanced Options I see the following:
Share folder owner: root
Share folder group: root
If I try to change it to nobody and nogroup, after pressing apply button it goes back to root/root.
Is this how should it be, or there's a bug in the software? Just maybe a remark one of the hard disks is USB 3.0 and connected to the front port (USB 3.0) and the other one is USB 2.0 and connected to one of the ports on the back.
And after creating backup job from Backup to Hard Disk I get error with the following log:
INCREMENTAL Backup started. Thu Nov 22 00:44:05 CET 2012
Job: 002
Protocol: local
Source: [backup]/
Destination: [USB_HDD_3]//GAMEZ
`./vip0988.sfv' -> `/USB_HDD_3//GAMEZ/vip0988.sfv'
cp: cannot create regular file `/USB_HDD_3//GAMEZ/vip0988.sfv': Read-only file system
cp: cannot create directory `/USB_HDD_3//GAMEZ/BLES01717-[Call of Duty Black Ops II]': Read-only file system
cp: cannot create directory `/USB_HDD_3//GAMEZ/BLES01636-[Medal of Honor Warfighter]': Read-only file system
cp: cannot create directory `/USB_HDD_3//GAMEZ/$RECYCLE.BIN': Read-only file system
cp: cannot create directory `/USB_HDD_3//GAMEZ/Saints Row The Third The Full Package Eboot Patch PS3-DUPLEX': Read-only file system
cp: cannot create directory `/USB_HDD_3//GAMEZ/BLUS31062-[Saints Row The Third The Full Package]': Read-only file system
`./b4e-flyer.jpg' -> `/USB_HDD_3//GAMEZ/b4e-flyer.jpg'
cp: cannot create regular file `/USB_HDD_3//GAMEZ/b4e-flyer.jpg': Read-only file system
cp: cannot create directory `/USB_HDD_3//GAMEZ/BCES01531-[Wonderbook Book of Spells]': Read-only file system
`./Binaries4ever.Net.url' -> `/USB_HDD_3//GAMEZ/Binaries4ever.Net.url'
cp: cannot create regular file `/USB_HDD_3//GAMEZ/Binaries4ever.Net.url': Read-only file system
cp: preserving times for `/USB_HDD_3//GAMEZ/.': Read-only file system
Backup failed. Thu Nov 22 00:44:05 CET 2012.
Reason for failure:
Error encountered copying data from source path ==> /USB_HDD_3//GAMEZ due to unknown reason. Please see log.
Please share with me if you have any ideas how to backup to my hard disks again.
Many thanks!!!
Job: 002
Protocol: local
Source: [backup]/
Reason for failure:
Many thanks!!!
