superandrea
Nov 11, 2012Aspirant
Problem with New Backup Job in FrontView
I have browsed every possible place, there are a couple of look-alike subjects on the forum but none gives a solution for the following problem: "the source path is invalid. please check the path and...
superandrea
Nov 22, 2012Aspirant
Thanks for your update xsspeed03, solution for your problem sounds fairly simple - I believe that with mine it goes over rights, which I cannot change in Frontview for some reason - so, CaseyH, I still count on your expertise and input!! ;-)
