superandrea
Nov 11, 2012Aspirant
Problem with New Backup Job in FrontView
I have browsed every possible place, there are a couple of look-alike subjects on the forum but none gives a solution for the following problem: "the source path is invalid. please check the path and...
CaseyH
Nov 26, 2012NETGEAR Expert
Superandrea,
Your ReadyNAS isn't part of a domain right? I think your PS3 is setting the file permissions to root/root. You can use Shares\Shares Listing\CIFS\Advanced Options and set owner = nobody , group = nogroup and check the box for "Set ownership and permission for existing files and folders in this share to the above settings. This option is useful in cases where you are changing security levels and need to workaround file access problems." This will reset the permissions back to full access. If that does not work enable FTP service and set Read/Write access for FTP service on the USB device then ftp to the ReadyNAS and use the chmod -R 777 USB-SHARE to set full access to that share.
