lubomir_maleev
Apr 03, 2013Aspirant
Problem with raid failed
Hello, I would like to ask about your support. I have a Netgear Ready Nas Duo v1 and adter few power fails in the house where i live, the Ready Nas dissapeared. Than i restarted only the settings a...
Apr 03, 2013Guru - Experienced User
100% sure that v1 products are limited to 2 TB internal drives, and are not capable of using bigger drives. You might have an ultra-2 or pro-2, but you can't be using a duo v1 with GPT formatted drives.
What firmware are you running?
To your second question - you'd see ext3 or possibly ext4, depending on what model you actually have and what firmware it is running. Which means that a normal PC running windows would see file systems they don't recognize.
