mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
dbott67
Nov 20, 2009Guide
It could be related to this:
http://home.bott.ca/webserver/?p=260
If not, can you please provide the following information:
- version of RAIDiator (i.e. 4.1.6)
- type of network connection on Windows 7 machine (wired or wireless; 100 Mbps or gigabit, 802.11a/b/g or n, etc.)
- make & model of router/switch
As a baseline during troubleshooting, we always try to eliminate some of the variables, so using wired rather than wireless can help eliminate some of the possibilities, as can performing a direct-connection. These are used to try to identify/isolate the issue and then we can proceed from there.
