mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
mjcairney
Hi, and thanks for your response.
To answer your questions, as follows:
1) RAIDiator v 4.1.6
2) I have tried both wired and wireless and it makes no difference. 100Mbps 802.11g
3) Sky supplied router - Netgear DG834G.
Cheers,
Martin.
p.s. I should have added that I do not have auto-update switched on.
Cheers,
Martin.
