mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
mjcairney
Nov 21, 2009Aspirant
I must admit I'm not sure how to do that.
However, whilst having another play around with it earlier on, I had the same problem, but when the message appeared, as usual I was offered the options to Try Again, Skip or Cancel - this time, I chose Skip and the file transfer was successfully carried out. I tried this another couple of times, each time resulting in a successful file transfer.
I don't understand this, but if that's all I need to do to transfer files, then I'm not going to worry about it.
Cheers,
Martin.
p.s. I really do appreciate your efforts to help me - thank you. :)
Cheers,
Martin.
