mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
mdgm-ntgr
Nov 22, 2009NETGEAR Employee Retired
rick.brewer wrote: I have the exact same problem. File copies larger than 400 MB and the entire device hangs up.
What I have figured out though, is that if I delete the current snapshot and then make a new one, the file copy works just fine.
Not sure what causes it, but it is a big pain to deal with. It needs to get fixed some how.
What version of RAIDiator?
What router?
Have you tried a direct connection?
How much space have you allocated to snapshots?
