mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
rick_brewer
Nov 23, 2009Aspirant
ONESIMUS wrote: How large is the file you are trying to copy to the media folder?
Are you able to try from a Windows XP computer? And does that fail also?
Windows XP fails as well. It fails just a hair past 400 MB copied. However, I am not copying into the Media folder. I am copying into a share I created.
