mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
ONESIMUS
Nov 23, 2009Aspirant
Try with your antivirus software turned off.
I assume you know that the files you are copying are virus-free.
Some antivirus programs causes a very large delay on large files and result in failed file copying.
