mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
ONESIMUS
Nov 23, 2009Aspirant
A few more options to try:
turn OFF Jumbo frames, if you have it on (if this works, you have incompatible NICs with Jumbo frames)
try another switch between your computer and the ReadyNAS (if this works, your switch probably has bad memory in it)
