mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
mdgm-ntgr
Nov 25, 2009NETGEAR Employee Retired
Argor wrote: havent set up any form of backup/snapshot yet.
just trying direct connect now.
Copied 9gb of pictures roughly 1mb in size each with no problems.
Moved onto movies and struggling to get anything to copy. Interesting to note that when i select multiple files for the copy it nearly always fails but a single will mostly work.
getting speeds b/n 8-9 MB/sec connected with cat 6.
What standard file protocol are you using?
