mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
mjcairney
Jan 15, 2010Aspirant
evo678 wrote: Update from my earlier post - problem fixed (at least for the time being). :D
It appears to be related to the auto-scan feature of ReadyDNLA. If you update the ReadyNAS settings by logging in as Admin:
Services->Streaming Services->ReadyDNLA just untick the "Automaticall update database" box.
The problem then went away; not sure I understand why, but never mind.
Would be good to let Netgear know
Martin
I did the same as you and everything seems to work okay although, like you, I have no idea as to why - thanks for the tip.
Cheers,
Martin.
