mjcairney
Nov 20, 2009Aspirant
Problems copying files to Media Folder on ReadyNAS
I have just recently purchased and installed my ReadyNAS 2150 and would appear to have a problem, although it may well be down to my lack of product knowledge. Anyway, the problem is when I go to Bro...
mjcairney
Jan 15, 2010Aspirant
dbott67 wrote:
evo678 wrote: Update from my earlier post - problem fixed (at least for the time being). :D
It appears to be related to the auto-scan feature of ReadyDNLA. If you update the ReadyNAS settings by logging in as Admin:
Services->Streaming Services->ReadyDNLA just untick the "Automaticall update database" box.
The problem then went away; not sure I understand why, but never mind.
Would be good to let Netgear know
Martin
I believe the issue is fixed in the current ReadyDLNA release 2009/11/09 (viewtopic.php?f=76&t=27946).
It should also be noted that the 2nd post in this thread (dated Nov. 20/09) had the same solution posted 8) :
dbott67 wrote: It could be related to this:
http://home.bott.ca/webserver/?p=260
I have installed the add-on as recommended - thanks for the link. I realise that the link was made before but have to admit that, being a newbie to ReadyNAS, I did not pick up on it.
Thanks again,
Martin.
