Nico76
Jul 13, 2016Aspirant
Problems expanding ReadyNas 104
Hi All, I seem to be having no end of problems with my Readynas 104 since purchasing over a year ago. After multiple replacement parts from Netgear, my most recent issue has been expanding the NA...
Nico76
Jul 15, 2016Aspirant
It still says X-Raid on right hand side of Admin page??
Have I lost my data?
Any suggestions to get this working as it should be?
- StephenBJul 15, 2016Guru - Experienced User
That is a control, and is always shown. If the X-Raid control has a green stripe through it, then X-RAID is enabled, otherwise it isn't. See page 26 here: http://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
Perhaps. I suggest contacting netgear support (though they will charge). Per-incident support might be all you need to re-mount the volume, if the data is actually gone then you'd need data recovery.
Though I don't want to rub salt in an open wound, RAID is not enough to keep data safe.
- Nico76Jul 15, 2016Aspirant
I've already contacted netgear support and the directed me to the forum. Not sure why I shoudl pay for support while the unit is still under warranty...?!
I've looked at page 26 of the attached - how to switch between X-raid / flex raid. I now get the following error when attempting this...
I also have the following errors...
- StephenBJul 16, 2016Guru - Experienced User
If you have a backup, then the easiest way for you to proceed is to do a factory default, rebuild the NAS in XRAID and restore the data from the backup.
If you don't have a backup, then you either (a) lose the data (b) try to recover it on your own or (c) pay netgear (or someone else) to try to recover it for you.
(a) might be painful, (c) could be expensive and might fail. If you don't know what you are doing, then (b) is not a good path.
Well, this is not a support forum; this is a community forum. We'll give advice, but that's it. Occassionally a netgear person might offer to access your system remotely, but I don't work for Netgear and that's not something I will do.
Support likely directed you here because you refused to pay.
Netgear warranties the hardware, not the software. And it's not clear to me at this point that its a software issue either. If you feel your local consumer protections apply, then that's something to take up with Netgear, not here.
It's too late now, but if you were in flexraid, that might explain the expansion problems that started you down this path.
