XtheUnknown
Feb 09, 2017Apprentice
Problems with integrated Egnyte app after 6.6.1 upgrade
Since we upgraded from 6.6.0 to 6.6.1 we've had a lot of problems with the integrated Egnyte app "Storage Sync". Every day it loses the mappings of our Egnyte accounts to our Windows Domain accounts ...
FramerV
Feb 11, 2017NETGEAR Employee Retired
Hi XtheUnknown,
Unfortunately we do not recommend rolling back.
Have you tried disabling the AV to see if it has any effects on the issue?
XtheUnknown
Feb 12, 2017Apprentice
Hi FramerV,
No, as we'd like to keep the AV support on. I've seen reports elsewhere though that the new 6.6.1 AV engine is causing other problems so we can try that to see if it is a workaround.
I'd really expect that now, as Egnyte is integrated into the OS, that there would have been extensive testing before release to pick up any problems/conflicts...
