Dewdman42
Oct 10, 2018Virtuoso
problems with Windows10 connecting to SMB share
I have been using SMB shares from my Readynas for a long time in home network with mostly all macs, but recently I changed one machine to a Windows10 machine and have had some issues with SMB. It wo...
Dewdman42
its working 100% with my macs, by name, nothing needed in hosts file.
I don't know if its the name on windows10 or what...don't know if there exists a hosts file for windows or where that would be.
Sandshark
Oct 10, 2018Sensei - Experienced User
Yes, it is clearly a Windows issue. If you don't know if it does the same thing using the name and IP, then try it. Google is you friend for the Windows Hosts file location.
- Dewdman42Oct 10, 2018Virtuoso
couldn't get IP to work at all. I realize its a windows issue but I was hoping someone could tell me whether there is something about workgroup or some other setting or something Readynas may be doing to present itself to the windows computer as something other then a simple SMB share. Windows has all this automatic stuff it does when it detects windows networking devices...which I don't understand.
After sitting a while, it worked briefly again, then when I tried VPN, that immediatley killed the SMB connection
