GunnarBergkvist
Feb 17, 2013Follower
Product enabling ReadyNAS to connect to Wi-FI network
Have just changed ISP and received from them a Netgear gateway CG3100. The Internet connection and the gateway is due to this now at the other end of the house, hence I have to use Wi-FI to connect my...
ahpsi1
Feb 18, 2013Tutor
+1 on going wired, but if that is not an option the Netgear WNCE2001 universal WiFi adapter might be a good fit -> http://www.downloads.netgear.com/files/GDC/WNCE2001/WNCE2001_DS.pdf. Aside from an annoying bug where it can under rare circumstances spit out DHCP addresss on it's own without being told to do so it does a pretty good job of providing wireless access for a device that only has a CAT5 port. Additionally, you can power it with an included USB cable adapter. Here's a bit more information on this fascinating little device -> http://bangbangsoundslikemachinery.blogspot.com/2011/10/anatomy-of-netgear-wnce2001-wireless.html.
