GunnarBergkvist
Feb 17, 2013Follower
Product enabling ReadyNAS to connect to Wi-FI network
Have just changed ISP and received from them a Netgear gateway CG3100. The Internet connection and the gateway is due to this now at the other end of the house, hence I have to use Wi-FI to connect my...
Feb 18, 2013Guru - Experienced User
Overall, performance will be best if you connect the NAS via ethernet directly to the CG3100. That is also the cheapest, since you don't need any more equipment.
If that can't be done, then you could use powerline, or something like the WNCE2001. There are several other Netgear choices here.
