MattieG72
Sep 19, 2018Aspirant
putname+10 error after 6.9.4 upgrade... :(
Hi All
I've just updated to 6.9.4 and now have an error "putname+10" on the lcd screen after 40 minutes of waiting :(
What do i, do I switch it off and hope it reboots back up??
Anny a...
SoCalNasUser
Sep 21, 2018Tutor
If you bring up the Boot Menu (paper clip on Reset hole / button on back and then hit Power Button) and reinstall firmware, it should put you back at network defaults (and the default password, too, just as a heads up) ... at which point you should have a machine that works (at least until you try to tweak the Network settings at which point it will die immediately.).
