euphos
Apr 30, 2015Aspirant
Question on Scrub procedure and what happens
I ran the new 6.0 version of RAIDar on my RN104, and saw a "diagnostics" button so I ran it. The test only showed disk 2 having some command timeouts. So, I decided to run a scrub to make sure data ...
mdgm-ntgr
Apr 30, 2015NETGEAR Employee Retired
Can you download the logs using RAIDar 6.0 then send them to me (see the Sending Logs link in my sig)?
The scrub makes sure the disks are all synced up. This puts heavy stress on all of the disks. If a disk is failing it can finish it off.
