euphos
Apr 30, 2015Aspirant
Question on Scrub procedure and what happens
I ran the new 6.0 version of RAIDar on my RN104, and saw a "diagnostics" button so I ran it. The test only showed disk 2 having some command timeouts. So, I decided to run a scrub to make sure data ...
euphos
May 01, 2015Aspirant
mdgm wrote: I'd agree with Nhellie that you should test the disks using the disk manufacturer's diagnostic tool.
I just sent the logs, so is this comment based on those? I'll pull the disk and check ASAP, but I want to make sure it's not in the middle of a recovery. Or is there a way to check the disk without pulling it and attaching it to a PC?
PhpSysInfo seems to indicate the rebuild is finished (ie nothing is showing up), but I still cannot access the admin page. RAIDar 6.0 diagnostics now shows:
2015-04-30 07:18:05: md/raid:md126: raid level 5 active with 2 out of 3 devices, algorithm 2
2015-04-30 07:18:04: md/raid:md1: raid level 6 active with 3 out of 4 devices, algorithm 2
And the main RAIDar screen "Status" is "Management Service is Offline".
RAIDar 4.3.8 has a blue dot at the beginning of that status line, flashing green dot under Volume Status, and a flashing green dot under Disk 3 Disk Status. When I hover over the green dot under volume status, it indicates"
Volume data: RAID Level 5, Recovery 0.0% complete, Time to Finish 35791394 hr 7 min, Speed 0 MB/s, 6.9TB (70%0 of 9.9TB used.
That's been the same status since yesterday morning when it started the recovery. It hasn't progressed, even though checking the status with PhpSysInfo showed it progressing, and now appears to be finished.
