peteophoven
Apr 17, 2017Aspirant
Quick question about expanding a volume with a ReadyNAS Pro 6
Dear Community,
I have A Ready NAS Pro 6
3x1TB
It is runnign verison 4.2.30
Wondering if I could expand and create the best redundancy as possible.
I was thinking 3x4 WD Red drives - Enterprise.
I believe I cannot expand the current volume over 8 TB right?
Would I add the drives one at a time, allowing for time to sync, using 2x4TB drives for expansion and then the last drive for redundancy only?
What do you recommend.
I really need 8TB total, but want to be smart about adding the drives to allow for maximum redundancy, so if two drives fail I will still be okay, and as well providing me with the most space possible without hitting the 8TB limit?
Please advise.
Thanks
There are two expansion limits with XRAID:
- a volume cannot grow more than 8 TiB over it's lifetime
- a volume can expand over a 16 TiB ceiling
The first limit applies here.
If you initially installed 3x1TB, then you can grow your volume to about 10 TB.
If you initially installed 1TB, and then added the other two, then you can grow your volume to about 9 TB.
If you have a 9 TB ceiling, then you can replace two of your 1 TB drives (one at a time) with 4TB models, and install the third 4 TB drive in an empty slot. You'll end up with a 9 TB volume.
If you have a 10 TB ceiling, then replace one of the 1 TB drives, and install two 4 TB drives in empty slots. You'll end up with a 10 TB volume.
Once you hit the expansion limit you need to do a factory reset to expand further. That will destroy your data, so you will need to restore it from a backup.
peteophoven wrote:
... but want to be smart about adding the drives to allow for maximum redundancy, so if two drives fail I will still be okay,
You have single redundancy now. If you want dual redundancy, then you need to have four drives of the largest size - not three.
You'd follow the guidance above to expand the volume. There is a checkbox that let's you choose to add the final drive for redundancy. You'd check that box, and install the fourth 4TB drive in an empty slot.
peteophoven wrote:
...I was thinking 3x4 WD Red drives - Enterprise.
WD Reds are good drives (I use them in my own ReadyNAS). They are NAS-purposed, acoustically quiet, run cool, and have 3 year warranties. But they are not enterprise drives.
WD Red Pros are the enterprise models. They run at 7200 rpm, so they use more power and your NAS will have higher temps. Performance will be better in some cases (in others your network limits your performance, not the drives). They have 5 year warranties.
- mdgm-ntgrNETGEAR Employee Retired
If your volume capacity was 1.8TB when you last did a factory default (wipes all data, settings, everything) you can't expand past 9.8TB.
You can't expand past 16TB. You can do a factory default with higher capacity disks in place.
OS6 doesn't have these limitations.
You could update your regular backup (e.g. to a USB disk), verify your backup is good, power down, remove your 1TB disks (label order), put the 4TB disks, do a factory default (wipes all data, settings, everything) and restore your data from backup.
To be able to use dual-redundancy you'd need at least four disks (RAID-6 requires a minimum of four disks) and the capacity of two disks would effectively be used for redundancy. Note that parity is distributed amongst all the disks so there is no dedicated parity disk.
Dual redundancy provides some protection against dual disk failure, but backups are still important. Don't store important data on just the one device.
- SandsharkSensei
Starting over with a factory default and the new drives (plus the old if you like) is going to be your best long-term solution. And if you are going to factory default, now is a good time to think about upgrading the unit to OS 6.x. But 6.7.0 and 6.6.1 have a lot of problems, so I recommend 6.6.0 for now. Since the Legacy to OS6 .bin file is constantly updated to the latest version, I'm not sure where you would get the file. I believe there are instructions on creating one burried deep in the thread for OS6 on Legacy NASes.
If you have a current backup device capable of handling all the data, then just update the backup and get going. If you don't, you could put one 4TB drive in a USB enclosure, back up to it, factory default with everything else in the NAS, restore backup, then add the last 4TB into the array. But you really should have an onging backup strategy.
- peteophovenAspirantThis is a great response. Very comprehensive.
I see the advantage of a factory reset but I really have little room to be out of production.
I think adding 3x4tb drives, staged, one at a time will do the trick.
The the third for redundancy.
We started with 3x1tb giving us 1.8 as the volume size.
Will I lose capacity due to parity when adding the 4tb drives?
When I add the the third drive and indicate redundancy - will the resync cause my volume to be offline?
Thank you.- mdgm-ntgrNETGEAR Employee Retired
With 3x4TB disks you'd expect roughly 4x the volume capacity you have now.
Will I lose capacity due to parity when adding the 4tb drives?If you go back to my earler post, you'll see I covered this case.
Your volume can grow to 9.8 TiB (~10.8 TB), but no more. If you simply add the three 4 TB drives (leaving the 3x1 TB in place) then you would have an 11 TB volume - just over the limit. When you try to add the last drive the expansion will fail.
That is why I said you'd need to replace one of the 1 TB drives with a 4 TB drive. Then you'd end up with 2x1TB+3x4TB, with a volume size of ~9.1 TiB (10 TB).
The general capacity rule for XRAID single redundancy is "sum the drives and subtract the largest". In your scenario you need 4 TB of parity blocks. Anything less can't recover from a failed 4 TB drive. With dual redundancy, you need an additional 4 TB of parity blocks (computed differently) - anything less can't recover from two failed 4 TB drives. These parity blocks are evenly distributed across all the drives.
peteophoven wrote:
When I add the the third drive and indicate redundancyThat's NOT the process if you are adding 3x4TB.
Here are the steps:
- remove one 1TB drive with the system running
- hot-insert the first 4 TB drive into that slot. Wait for resync to complete. Final volume size will be 1.8TiB.
- hot-insert the second 4 TB drive into an empy slot. Wait for resync to complete. Final volume size will be 4.5 TiB You might need to reboot in the middle of the resync to get that expansion (the system should prompt for that).
- hot-insert the third 4 TB drive into an empty slot. Wait for resync to complete. Final volume size will be 9.1 TiB
If you want dual-redundancy (protection from two drive failures), you add these steps at the end
- indicate that you want to add a disk for redundancy
- hot-insert a fourth 4 TB drive into an empty slot. Wait for resync to complete. Final volume size will still be 9.1 TiB (with 8 TB of parity blocks).
peteophoven wrote:
will the resync cause my volume to be offline?No. The system is available during resyncs, but at a reduced performance level. Resync times will go up as you add more disks, and will take quite a bit longer if you add the 4th 4 TB drive (since it doubles the number of parity blocks that need to be computed).
During the first series of steps, the volume is not protected from failure while a resync is in process. So it is particularly important to have current backups during those steps. If you go with dual redundancy, the volume is protected from single-disk failure during the resync with the final 4 TB drive.
Replacing the 1 TB drive with the 4 TB drive will resync pretty quickly, so doing it off-hours during the work week will probably be ok. After that, I'd suggest doing the hot-insertions on the weekends. Note you will probably will need to reboot when the second 4 TB is inserted (part-way through the resync).
- SandsharkSensei
I see the advantage of a factory reset but I really have little room to be out of production.I can see that being an issue if you don't have enough down time (like a weekend) in which to perform it. It's just that with under 1.8TB of data, it's a lot easier to restore all that now than if you find you need to expand again after you've filled your max volume expansion. Moving to OS 6.0 lifts that limit, too. You are completely down with a factory reset and restore, even if you don't go to OS 6.x, while you are not during an expansion only.
