bruceM1
Jul 30, 2014Aspirant
R102 Netgear backup Fail: destination is read-only.
All the backup jobs succeed on a new usb hard disk, but on the other of the same type, the same jobs ran a few times, and then started failing. They are NTFS formatted, and when I plugged the offendi...
Marto731
Jul 31, 2014Aspirant
Bruce,
4 points.
(a) Is Continuous protection on, for the Share being backed up?
Could you try hourly/ daily?
(b) Latest F/ware is V6.1.8 http://support.netgear.com/product/RN10200#wrapper
(c) Can you advise manufacturer and model # of USB.
(d) You can't rule out a hardware issue with 2nd HDD.
Regards, Marto
4 points.
Regards, Marto
