Tauro
Feb 21, 2021Aspirant
RAID sync finished on volume C. The array is still in degraded mode, however. This can be caused b
ReadyNAS Duo V2 RND20000-200AJS Model RND-2B SN 2UM325EV000F9 Previously I had 2 x 2TB drives installed. All working fine RAID leverl XRAID2. Seagate NAS HDD ST2000VN000 2TB WD Black 2003FZEX 2T...
- Feb 24, 2021
Tauro wrote:
This has gone from bad to worse. Tried factory reset with new disks installed.
1. Used paperclip method described here RND2000NAS Duo Factory reset
First of all, if the disks were blank there is no need for a paperclip. It will detect that, and do a fresh factory install.
Second, you used a guide for the Duo v1, not the v2. The correct instructions are on pages 16-17 here: https://www.downloads.netgear.com/files/GDC/RND2110/ReadyNAS_Duov2_NV+v2_HW_en_23-Mar-12.pdf
Tauro wrote:
Surely someone has a suggestion I have not tried?
Try removing the disks and power up again. Then see what status RAIDar gives you. https://kb.netgear.com/20684/ReadyNAS-Downloads
I also suggest testing the new disks with vendor tools in a Windows PC - lifeguard for Western Digital; seatools for Seagate. Run the full long generic test. Unformat them while you are at it (either with the Windows disk manager, or by doing the erase test in the vendor tools). After that, try inserting only one of the disks in to the Duo, and power it up. It should do a factory install (again no paper clip needed). Using only one disk will be quicker, because no RAID sync is involved. Once you get access again, you can hot-insert the second disk.
Tauro
Update.
I checked the first disk in a dock and it only showed 2TB and was MBR.
Used diskpart to clear the volume and convert to GPT. THe disk showed up as not initialsed in disk management.
Installed back in to the NAS and powered up, opened RAIDar app and they now both show as 3726GB and all lights are green.
New issue now is I cannot access the folders via a network path. They are still present in settings shares but under volumes there is nothing present and the light for volumes is darkened out.. Also unable to access via file explorer in Windows 10 OS.
I do get the prompt to enter credentials but this still fails. Also cannot create a new folder under shares. Keeps saying the name in not valid and I need to use alpha numeric characters for the share name. Thinking I may have to reset this to facotry or recreate a new volume and shared folders.
Any suggestions is apprecited.
