styks1987
Feb 12, 2018Aspirant
RAIDar Corrupt Root RN31400 Could Not Mount Root Raid d(isk)
LCD SCREEN: Could Not Mount Root Raid d(isk) RAIDar Status: Corrupt Root Issue after power loss. I do not want to reset to factory as I have data I do not want to lose. I have tried: - OS...
styks1987
Yes, I believe this is true. It looks totally corrupted. It cannot even be mounted. Any way to reinstall the os from scratch?
# /bin/start_raids mdadm: /dev/md/0 has been started with 4 drives. mdadm: /dev/md/1 has been started with 4 drives. mdadm: /dev/md/data-0 has been started with 4 drives. Imported RAID data-0 Updating fstab entry: 7c6ea5aa:data => 7c6ea5ab:data mount: mounting LABEL=7c6ea5ab:data on /data failed: No such file or directory # mount /dev/md0 /sysroot mount: mounting /dev/md0 on /sysroot failed: Input/output error
styks1987
Thanks for the solution. Just posting here in case someone else needs this info.
dmesg log showed that my btrfs filesystem log was off. He zeroed out my log (which is really dangerous) but because it was only off by 1 it was not as dangerous. Also, this was on the os partition.
I'm going to go find a battery backup....
