nvmu
Dec 30, 2011Aspirant
RAIDar not showing Ultra 2
Hi,
Suddenly this morning RAIDar will not show my Ultra 2 (RNDU 2000), however it had no problems working the previous couple days. I can however still access it via normal methods, typing in its local ip, using readynas remote.
RAIDiator v 4.2.19
RAIDar was 4.3.0, but saw that 4.3.4 was out so I updated to see if that would fix the problem, did not.
As I can still access setup it is not a major problem, however I liked the convenience of opening up RAIDar to quickly check fan rpm/temps. I did not change anything in my router over night, or firewall settings, ect.
May be important info, but I am not sure; I had the NAS power itself down using Power Timer for the first time.
Thanks,
nvmu
RAIDiator v 4.2.19
Thanks,
nvmu
1 Reply
- nvmuAspirantUpdate:
Ok, for whatever reason, today RAIDar wouldn't even open, or let me uninstall from control panel.
However, I downloaded it again and installed it; it uninstalled itself and then reinstalled. And now it works, kinda odd but hey I'm not going to complain about it.
So if a mod wants to delete this thread by all means go for it.
