TT_DE's avatar
TT_DE
Luminary
May 08, 2017
Backup NAS 2 USB HDD stops unforeseeable after 500 GB
Having bought a new usb hdd 5 TB a few months ago and set up this device as backup device for the NAS 516. The first full backup worked fine. During the last weeks the nas run incremental backups da...
  • TT_DE's avatar
    TT_DE
    May 09, 2017
    Having checked the whole setup including format and cable I could identify a malfunction of the power adapter of the hdd which caused the backup errors.
    There has been a loose contact in the 12 volt power adapter. I changed the adapter and the backup run properly and ended succesful without interruption.
    Surprisingly the brand new power adapter was delivered with a malfunction.
    Thank you to you all for your helpful and kind recomendations - I have learned a lot regarding doing backups properly.
ProSupport for Business
