Deeperdown
Mar 12, 2021Tutor
C Drive Failure/Faulty Drives
Hi All, This evening my NV+ stopped working which was noted by the TV saying "no contect". Upon investigation, i identified that the NV+ had locked up in that it was still on, powered and showing "...
Deeperdown
Mar 15, 2021Tutor
thanks - will re-check the dock station tomorrow and settings as per yrou advice and will report back tomorrow.
Deeperdown
Mar 16, 2021Tutor
OK, so i did as you instructed above re the dock station and it still comes up the same, so the USB & SAS are both the HDD (2TB) that I'm testing. Im also getting various results. Ive attached a screen dump while testing Disck 4 (which failed it long Generic test) and drive info from both (not the SDD).
