daztrue
Aug 06, 2015Aspirant
Drive Tray Screws
On this and this thread you tell users to contact you with their case number (4566674) after contacting support. Like others, I too was told that Netgear don't provide screws or have detail o...
- Aug 07, 2015
Hello daztrue,
Thanks for getting back.
Mdgm is correct, your case number is 25550932 where you have spoken with one of the support people. Unfortunately your ReadyNAS is out of warranty so they could not give you disk screw replacement.
We apologize if you were not given details about the disk screws. It is part number 370-10001-01 for 20 pcs and 370-10002-01 for 100 pcs. available for purchase from support center if you are from the US, unfortunately not in UK.
The disk screw is a 6-32 thread 4mm long countersunk flat head
Here are some resellers I found online:
Hope this helps you.
daztrue
I and other users in the other threads have been told by support that Netgear don't provide the screws or have details of the part. Numerous users have attempted to find them from retailers as well to no avail.
My case number is 4566674.
