ronaldvr2132
Mar 09, 2020Apprentice
Hard disks are continueous active even when no one is using the NAS
For both my RN628X devices the hard disks are continueous showing a lot of activity (both the led's are flashing and also the sound suggest quite a lot of disk activities). This is also when there is...
Mar 10, 2020Guru - Experienced User
ronaldvr2132 wrote:
For both my RN628X devices the hard disks are continueous showing a lot of activity (both the led's are flashing and also the sound suggest quite a lot of disk activities). This is also when there is no one using the NAS and also the NAS is not doing back-up jobs or anything else that I can explain.
Have you downloaded the full log zip file for both systems, and looked for clues?
Another approach is to enable SSH, and run top when you see the activity. Then see what processes are using the CPU and try to track that back.
Also, have you scheduled maintenance tasks on the NAS (volume settings wheel)? If you have autodefrag set, you might try disabling that. Maybe also turn off file indexing and antivirus, and see if that makes any difference.
Is one of these NAS your backup NAS?
ronaldvr2132
Mar 10, 2020Apprentice
Hi StephenB thank you for your feedback. I can't see anythng strange in the logs. I do have Anti Virus, File Search and Audit enabled on my main NAS the other NAS (my back-up NAS) only has Anti Virus and File Search enabled. I have switched off these two on my back-up NAS to see if this affects the disk and other activities on my NAS significantly. Thanks
