Demon666
Sep 02, 2016Guide
How to backup/sync using FTP to ReadyNAS
Hello all, Here is my problem or need so to speak.. Will describe the setup first so we have everything as clear as possible. I've got a RN214 (ReadyNAS OS 6.5.1), with IP 192.168.10.1. I've ...
Sep 03, 2016Guru - Experienced User
Did you try taking away the first slash in the path (before media)?
Also, sometimes test connection misbehaves, so you might want to skip that and test the actual backup job.
Demon666
Sep 05, 2016Guide
Hi Stephen,
Yup, I've tried to omit the first / in the beginning of the path, but sadly enough that didn't solve the problem.
According to the log the job completes with out errors, but the biggest issue obviously is that it didn't transfer any files.. :(
Now, I've done the following.
The reason I bought the RN214 was that I wanted to make sorting and datamoving life a bit easier by putting all my data from 2 separate 4TB RAID1 NAS-ses to just one RAID5 NAS with about 12TB.
I've revived one of my other NAS-ses (Netgear ReadyNAS Ultra 2), and added the exact same settings for the backup.
I've tried to leave the leading / away here, and also tried it with the /.
The logging of this backuptask is a whole lot more specific... Here it comes...
FULL Backup started. Mon Sep 5 09:10:31 PDT 2016
Job: 001
Protocol: ftp
Source: ftp://192.168.10.171/media/drive1/Video/Breakfast
Destination: [media]/
Error in server response, closing control connection.
unlink: No such file or directory
Backup failed. Mon Sep 5 09:10:34 PDT 2016.
Reason for failure:
Error encountered copying data from remote source path ftp://192.168.10.171/media/drive1/Video/Breakfast.
Hope this clarifies a few more things and helps you coming up with a solution :)
Demon666
- Demon666Sep 11, 2016Guide
Hello,
Almost one week has gone, no further replies here.
I hope this is just coincidence and there are people actually looking into this, it would be a great thing if this will be working in the end.Thanks in advance!
Demon666
- KCurtisJan 01, 2017Aspirant
ReadyNAS RN626x OS 6.6.0
I am having the same problem and I am not able to get Remote:FTP to work. I connect using Filezilla and also just by using IE.
Netgear!!!!!! Is it possible to get this to work?????? Is it a bug that you are working on to fix?
