makkistyle
Mar 17, 2024Tutor
how to downgrade my NAS firmware from 6.10.10
Hi, I'm not a developer geek and don't know how to use the codes or ssh is there easy way to downgrade the OS .. I searched and found option in admin page to do so .. but it requires me to u...
- Mar 22, 2024
Indeed, sources.list.d seems to be a place where apps can put their own sources.list and not worry that an OS update will change them. On my VM with Docker installed, it's sources list is there, called docker-cli-rnapp.list. Don't do anything with them. You need to put apt.conf and the updated sources.list in /etc/apt.
adinx
Oct 16, 2024Aspirant
Apologies for not responding earlier. Realised my volume was read only so been backing up my content over the last few days. Did a factory reset so currently rebuilding the volume. Will retry after its all done.
adinx
Update:
After restoring to factory settings due to the issue that was keeping my volume in read only, I downgraded to 6.10.9 and it allowed me install Plex from the featured apps section. Was also able to update Plex with a .deb file without having to use the mods. Thanks again for your help.
