Alpacaman
Apr 11, 2026Tutor
Migrating Disks from NV+ to NVX
Hello Folks, I'm new here ... I have / had an old NV+ NAS with four 1TB drives. I hadn't used it for years and when I got it going again the other day, all was well for a few hours, backing up my...
Sandshark
Apr 11, 2026Sensei
The power supply from the NVX can be moved to the NV+ if you are sure it's just the supply that's at fault. But if something else took the supply out, you could end up killing the NVX supply.
- AlpacamanApr 12, 2026Tutor
Excellent suggestion (why didn't I think of that?!) Then I can recover the data from the old disks before setting up the NVX afresh and disposing of the NV+ (does it have any value?) Cheers!
- StephenBApr 12, 2026Guru - Experienced User
The trays do, though the ones with the round buttons aren't as good as the newer ones with the square buttons. They can be used in any desktop ReadyNAS.
Selling the trays separately (with the screws) would give the most return. It could take a while to sell them though, since the NAS they fit are all end of life.
I'm pretty sure the PSU failed on its own ... we have a very stable 230V AC supply here in Somerset, UK. Perhaps a filtered outlet would provide a smoother waveform though.
- AlpacamanApr 13, 2026Tutor
Although [lightbulb moment] the PSU might have failed due to a failure of a component in the NV+ circuitry ... in which case the NVX PSU would then be at risk if I fitted it. I'll see if the NV+ PSU is repairable first.
