ndverge
Feb 16, 2016Aspirant
NAS not showing under Network again after update to 6.4.2
I recently updated the firmware of NAS device. after update, the NAS device not visible on the network. But I can type the name on the run command and access. But i want the nas device to be visible...
- Feb 18, 2016
I just switch off the and on our 8-port switch. then the NAS drive is visible to all the computers in the network. thans who supported me.
Feb 18, 2016Guru - Experienced User
ndverge wrote:
No. It's Windows 7. ????
Well, as I said earlier this is very hit-or-miss (and has been for a long time). It's hard to tell if its a bug in Linux or Windows. You can waste a lot of time trying to wrestle this to the ground.
One thing to check is the workgroup settings on the NAS and PC - they should match.
ndverge
Feb 18, 2016Aspirant
