davidr1
Sep 27, 2015Luminary
Nas &Ultra with OS6 Backup problem
Hi, I've successfully installed OS6 on my Pro & Ultra. Backing up to USB on the Pro & Ultra is a problem: 1. Is it possible to define either the rear left/right USB ports or the Front USB p...
Cliff_MI
Sep 27, 2015Guide
I am seeing the same issue on a Pro2.
The USB is defined as either Front, Top or Bottom.
My Pro has front, left and right
I can't define a USB backup since I updated to 6.4.0-T??
Is there a way to force it to use the left and right USB's
I am going to try and move it to the front and see if I can at least define some jobs to run.
The drive is addressable from where it is in the back, I can copy and move files to and from it using the browse options but will not work for backups
