HappyFriday
Jul 14, 2017Aspirant
No volume exists
So I ordered some new 8TB drives, to put into my NAS due to space issues. Rebooted and I am getting an error http://imgur.com/a/ewVgq so I went ahead and powered back down and threw the old drive ba...
HappyFriday
Jul 15, 2017Aspirant
Here you go, tell me what you think. Thanks for any help.
[Fri Jul 14 19:17:03 2017] md: md127 stopped.
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sda3 operational as raid disk 0
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sdf3 operational as raid disk 5
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sde3 operational as raid disk 3
[Fri Jul 14 19:17:03 2017] md/raid:md127: device sdd3 operational as raid disk 2
[Fri Jul 14 19:17:03 2017] md/raid:md127: allocated 6466kB
[Fri Jul 14 19:17:03 2017] md/raid:md127: not enough operational devices (2/6 failed)
[Fri Jul 14 19:17:03 2017] md/raid:md127: failed to run raid set.
[Fri Jul 14 19:17:04 2017] md: md127 stopped.
[Fri Jul 14 19:17:04 2017] md/raid:md127: device sdd4 operational as raid disk 0
[Fri Jul 14 19:17:04 2017] md/raid:md127: device sdf4 operational as raid disk 3
[Fri Jul 14 19:17:04 2017] md/raid:md127: device sde4 operational as raid disk 1
[Fri Jul 14 19:17:04 2017] md/raid:md127: allocated 5410kB
[Fri Jul 14 19:17:04 2017] md/raid:md127: not enough operational devices (2/5 failed)
[Fri Jul 14 19:17:04 2017] md/raid:md127: failed to run raid set.
jak0lantash
Jul 16, 2017Mentor
HappyFriday wrote:[Fri Jul 14 19:17:03 2017] md/raid:md127: device sda3 operational as raid disk 0
You have mixed capacities drives, 2TB and 3TB, which means you have (at least) two RAID arrays concatenated as a single BTRFS volume.
The NAS attempted to assemble the first RAID array (the base one) and failed as two disks are out of sync.
The NAS attempted to assemble the second RAID array (the secondary one) and failed as two disks are out of sync.
Two drives are out of both RAID arrays, so this is a Data Recovery situation. You should contact NETGEAR Support.
