Cherzem
Aug 13, 2024Tutor
Not able to list directories from Onedrive
I have had working Cloud services (Google Drive and OneDrive) on my ReadyNAS Ultra 4 Plus running 6.10.10 for a very long time. This time I wanted to add a session for the OneDrive service. This f...
strykeroz
Apr 25, 2025Tutor
vandermerwe wrote:Now it is clearly broken ,presumably Microsoft trying to stop us from easily using the storage.
I can't comment on other NAS being impacted, but granted it also fails on Wasabi, our NAS appears to be the common factor.
antibhain
Apr 26, 2025Guide
Microsoft is guilty of many things, but not this issue. This is 100% a problem on the Netgear side. No doubt something was changed to improve security on the directory listing call. Netgear needs to issue a Firmware update but that will not happen, They are gone from this business. I know some have held out in the hope they would release the source so that the community could keep things maintained. That's not happened by now, so it won't.
I've solved the problem anyhow. Moved to a Synology. Netgear is dead to me for any of their products, not just NAS.
- vandermerweApr 26, 2025MasterYes I’d also like to move to synology but waiting for update to their line of NAS, many of them are quite old.
- antibhainApr 26, 2025GuideYeah, Synology is very slow on hardware changes and are absolutely not bleeding edge on hardware. That said, they are very reliable. With them, it is all about the DSM operating system and app library and that's really what you're going to choose them for. Plus a huge user community.
There are, of course, other equally good alternatives from other vendors. People who have experience of those can chime in. In my case I replaced my ReadyNAS 314 4 bay with a DS923+. The quick summary of that is just "Wow".- vandermerweApr 26, 2025MasterYes I’m sure my experience would be the same. They are very expensive though and apart from these little issues with my Readynas devices they are also very reliable - I have 3 in operation a primary 316 as well as an Ultra 6 and NV+ which still run perfectly doing backups.
- StephenBApr 26, 2025Guru - Experienced User
vandermerwe wrote:
Yes I’d also like to move to synology but waiting for update to their line of NAS, many of them are quite old.Hopefully you know that going forward they are locking down their new platforms so you can only use Synology-certified drives.
At the moment, the only certified drives are the Synology branded ones. Synology is saying they will set up a third-party certification program, but no news on when that will happen, or how long it will take them to certify a new drive.
- vandermerweApr 26, 2025MasterOh, I read somewhere that it was only the rackmount nas devices that had to use their drives, whereas the desktop devices could use any disk (even if not necessarily on the list of certified disks)
On their website the 923+ has lots of 3rd party drives on the list. The 925+ doesn’t yet but it’s just been released. I assume it’s the same for other models.
I’m waiting for a new 5 or 6 bay device.
- SandsharkApr 26, 2025Sensei
Microsoft has made changes to OneDrive at this same time that affect users without a NAS. You can no longer select folders for backup in their GUI other than the standard ones they list in your personal folder, at least in the Personal edition of OneDrive. They are obviously trying to restrict what you can sync, but the hard link method is a currently working work-around. They may also be changing the security.
Microsoft absolutely did create this issue. Whether or not there is a companion change Netgear could make to restore functionality if they were still doing OS updates, I don't think anyone here can say for sure.
- vandermerweApr 26, 2025MasterI can still select folders for backup - not from the tray icon settings but after you open the OneDrive folder the settings at the top have a different interface where you can select folders for backup.
