ianw53
Jul 17, 2014Aspirant
Not Accepting Connections #23538265
I have a Readynas Ultra 6 which up until now has worked perfectly. However now it is no longer available. When running the windows diagnostics, it indicates that device is not accepting connections ...
ianw53
Jul 24, 2014Aspirant
The issue does appear to something with the DLNA server. If you try to access it using DLNA then the whole system just seems to disappear. You need to wait a few minutes before accessing shares, frontview etc. The Sony home theatre system sees the server but receives nothing from it. Have tried up dating to 1.1.2.3 however it fails each time and you then have to wait before you can get back into do anything.
