chasg
Apr 11, 2016Aspirant
novice ReadyNAS user: "volume expansion failed", how to address this problem?
Hi all, I'm very much a novice when it comes to this machine (I just have put in drives and used it) and I'm having a problem, really hope someone can help. I've just added a WD 6TB drive to my l...
Apr 14, 2016Guru - Experienced User
I've used both teracopy and robocopy for this. Robocopy is definitely slower (but is very robust and is reasonable for incremental backup).
For a one-time full backup, teracopy is a good choice. It will offer to replace the built-in windows copy - I suggest not letting it do that. If it does it silently, there should be a preference to turn it off.
chasg
Apr 14, 2016Aspirant
Great, thanks again. I have downloaded teracopy and it's counting files now :-)
Do you know what I need to click to set it to verify the copies? I've read their decriptive site, and read a couple of reviews, but none yet have mentioned verification.
- StephenBApr 14, 2016Guru - Experienced User
If you click on the "more" button you should see a verify button.
- chasgApr 14, 2016Aspirant
oops, missed that one! This is what happens with a Mac guy of 25 years experience puts a PC on his desktop as well (old reflexes and knowledge can sometimes lead me astray :-)
