powellandy1
Dec 02, 2020Virtuoso
Onedrive Backup Failure
Hi Struggling to get Onedrive backup set up (upload only). RN422 with 6.10.3. Set it up a couple of times (as pictured below) Repeatedly fails. Log shows: Dec 02 21:29:29 Backup ng-c...
- Dec 10, 2020
The dot (little "light") in the icon turns blue when the NAS is backing up the files.
Could you please follow this https://kb.netgear.com/25625/How-do-I-send-ReadyNAS-system-logs-to-NETGEAR-Support to download the system logs and then send it to me in a private message?
powellandy1
Dec 10, 2020Virtuoso
It does. On unlimited it works - but the internet grinds to a halt. It seems to go completely full pelt without saving a small % of bandwidth - which makes it pretty unusable except overnight.
Once I put a limit (I've tried 50KB/s and 150KB/s - my broadband upload is about 2Mb/s - so limiting to about half) in it seems to hang after an hour or two and the little 'light' turns from green to blue.
Bug in the throttling code??
B_L
Dec 10, 2020NETGEAR Expert
