Dave_Ams's avatar
Mar 17, 2016
Pro 6: Managment Services is offline (RNOS 6.4.2)
 All,   I have seen this issue on other posts but no direct answer. My NAS has stopped responding, Both WebGUI and SSH no longer work. It might have happened after it filled up.   Unfortunately n...
  • mdgm-ntgr's avatar
    mdgm-ntgr
    Mar 17, 2016
    There was a problem with the filesystem on the root volume, so I copied the contents off, formatted the root volume, copied the data back and fixed a few things with the root volume then booted it back to normal mode.
ProSupport for Business
