midim
Apr 30, 2019Aspirant
Ready NAS OS 6.10.0 Backup jobs not working
After upgrading from 6.9.5 to 6.10.0 Hotfix2 the backup jobs which were successful when running 6.9.5 after the upgrade are not working any more and every job is reported as fail. The log reports:...
937carrera
I am running 6.10.0 on an RN102.
There were no backup jobs on my system so I created one as a test earlier. I used windows timestamp and specified the source by IP address.
The backup worked. Have you tried creating a new backup job to duplicate an existing one and see if that runs to completion ?
midim
May 02, 2019Aspirant
Thank you for the time spent on this matter.
So after couple of tests ended up with after changing either the source or the destination of the job with ip address instead of hostname used.
The jobs are completed successfully. Changing the hostname with hostname.local also solves the problem because we are in AD environment.
We will monitor the jobs these days but for now it seems ok.
