Sa9aX11
Jul 30, 2018Guide
ReadyNAS 102 Remote Access
Hi
Do anyone know the port no. to access ReadyNAS device remotely?
What to use my ReadyNAS has a server so anyone can access my files, similar how you would see it locally on the web page. I ...
Aug 01, 2018Guru - Experienced User
Sa9aX11 wrote:
I want my NAS to be access outside (remotely) like a server so I or a friend can access and store files, play music & video.
Ok. There are risks there, since hackers also can gain access through the same protocols. So you definitely want to use secure protocols and use strong passwords. Also, you want to make sure you keep your firmware up to date, since most firmware releases include some security updates. There have been posts here from folks who have had their ReadyNAS hijacked, so this is not a hypothetical risk.
One potential option is ZeroTier. You can install it on the NAS, and also on the your own (and family/friend) devices. You'd have the ability to add and drop those devices through ZeroTier's web interface. This functions like a VPN, but the access is limited to your NAS, not your full home network. All the services (SMB, AFP, etc) would be available remotely. The normal NAS user accounts and file access controls could be used to limit the access of any friends.
And you could also try ReadyCloud.
Sa9aX11 wrote:
... FTP seems work ok remotely...
Yes, but it's not secure. The FTP server in your NAS supports FTPS, and you can configure it to require FTPS (ftp with explicit TLS). Many FTP clients support FTPS, including WinSCP, Filezilla, and several apps for iOS and Android.
Sa9aX11 wrote:
HTTPS & HTTP doesn't work remotely, tried also port 443 remotely I get nothing.
Again, HTTP isn't secure, so you shouldn't be setting that up for remote access (other than perhaps for public wordpress stuff).
If you have remote management enabled in your router, it might not actually forward 443 (even if it's in the port forwarding list). Some ISPs also block those ports - you might want to check that with http://canyouseeme.org/
One option with https is to enable the secondary port number in the NAS settings. Ideally the secondary port is in the range reserved for dynamic/private ports (49152-65535). Then forward that in your router, and specify it in your URLs. For instance, if you chose 54321 for the secondary port, you can reach the NAS with https://ddns-name:54321/admin
Sa9aX11 wrote:
I tried that its only good for playing music but not for streaming movies I get always the message that my system is not powerful enough.
I have used the RN102 for streaming movies. It's not able to do real-time transcoding, you'd need a more powerful NAS for that. If your network connection isn't fast enough for direct-play, then you could still do some off-line conversion (creating a lower quality version of the movie that can be streamed over the internet).
Another scenario is that your plex client might not support for the audio or video format - that's another case where transcoding might be needed. For instance, movies that use DTS audio. Again, off-line transcoding is the only way around this with the RN102.
These aren't just plex issues - you'll run into these issues with any streaming platform.
What is your ISP upload speed?
Sa9aX11
Aug 02, 2018Guide
I checked the ZeroTier site but I can't find the app that works on my NAS device, I looked at ZeroTier downloads I see no .deb versions, I checked out https://download.zerotier.com/debian/ and I see a few ending xxxx_armhf.deb that installs on my NAS Device but it doesn't appear on my NAS apps list, tried a few armhf on each directory it installs but nothing appears.
ReadyCloud don't like it its confusing, you need to create a link to share the files, I don't want to do that.
FTP or FTPS I want to use on my browser, don't want to use a separate program.
AICloud Web uses port 443.
AiCloud content streaming uses port 8082
As for my upload speed its 1-2Mbps its faster early in morning, my download speed 102 Mbps (Morning) & 40-60 Mbps (8 - 12.00am)
- StephenBAug 02, 2018Guru - Experienced User
https://github.com/NAStools/zerotierone/releases
Sa9aX11 wrote: FTP or FTPS I want to use on my browser, don't want to use a separate program.
Bad idea. Browsers don't support secure FTP. It's safe if you are accessing via a VPN, but not over the open internet. User names and passwords are sent as clear text with normal FTP, so hackers who can see the traffic can access your NAS using those credentials. FTPS eliminates that vulnerability.
That's enough for direct streaming of music and some SD video content, but not enough for anything else. Typical 720p movies need 3-6 Mbps; 1080p videos often need 8 Mbps or more.
Options include
- transcoding movies off-line to fit your internet bandwidth (probably keeping the higher quality versions for local viewing)
- upgrading your internet service to get a faster upload
- upgrading the NAS to a more powerful model that can do real-time transcoding
- hosting the plex server on a PC that can do real-time transcoding, keeping the content on the NAS
You can only forward an internet port to one device. If you are using 443 (and 8082) for AiCloud, then you can't use them with the ReadyNAS. If you aren't using AiCloud, then the ports it needs aren't relevant.
FWIW, port 443 is the standard port for https. Lots of stuff uses it - which isn't a problem when you are connecting outbound from your home network. But inbound you can only forward port 443 to one device. I told you how to overcome that in the previous posts.
- Sa9aX11Aug 02, 2018Guide
Zerotier-One they all failed to install tried nt1_ to nt3_armel.deb.
I switch off AICloud (443) & ReadyCloud don't like to use a link for a file.
- StephenBAug 03, 2018Guru - Experienced User
What firmware are you running on the NAS?
Are you saying that you don't have remote https access to the NAS when you've forwarded port 443 in your router with AICloud off?
