Calm
Sep 10, 2016Aspirant
readynas 104 replaced drive rebuilt data still showing data degraded
Have a readynas 104 - drive in slot 1 failed - tested new drive all tests passed replaced with same make and model it detects and rebuilds volume showing raid 1 once rebuilt it still comes up wit...
- Sep 14, 2016
Well I would backup the data onto another disk if you can (don't try and overwrite the existing data).
Then with only good new disks in the NAS do a factory default (wipes all data, settings, everything) and restore your data from backup.
Calm
Sep 14, 2016Aspirant
Hi Have sent logs as described in your post
thanks
Calm
Just had email bounce back at me please find attached link to log files http://www.computerneeds.com.au/download/System_log.zip
thanks
- mdgm-ntgrSep 14, 2016NETGEAR Employee Retired
Disk 2 is failing.
Unfortunately this is the disk with your data on it (the other disk is marked spare). Do you have a backup?
Either your old disk 1 or current disk 2 would be needed to try and backup data.
The disks you are using (ST3000DM001) have very high failure rates.
